It is currently Mon Aug 11, 2025 2:30 pm
 Post subject: Neck stripes wood
PostPosted: Wed Nov 18, 2009 5:50 pm
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
Zip/Postal Code: H4G 2Z2
I'm searching for hardwood (Bloodwood, ebony, Rosewood, etc...) for a laminated bass neck. How can I get those? I need about 34" long, that's what make this wood hard to find.
Francis Richer, Montréal
Les Guitares F&M Guitars
 Post subject: Re: Neck stripes wood
PostPosted: Wed Nov 18, 2009 5:58 pm
Most all hardwood dealer will carr the woods you mentioned. googel hardwood sales and tonewood sales and i am sure you will find what you need. Also check with Woodcraft and other woodworking supply sites.
PostPosted: Wed Nov 18, 2009 6:05 pm
Most of the chain stores like Woodcraft will be on the expensive side. Look for a lumberyard that does hardwoods. I found a good one around that I picked up some wood for basses, Walnut, HOG, Maple, Bloodwood, Padauk. Also some African Blackwood, Ziricote and Coco for fingerboards, head plates and bridge blanks. I got some really nice wood and with a little sawing got a great deal on blanks. If you spend sime time looking, you can find a few good gems, but even at a good lumber yard you have to sift through a lot to find them.
Also look at Gilmer. They usually have some wood for electric bass necks and stringers.
PostPosted: Wed Nov 18, 2009 6:06 pm
First name: Christian
Last Name: Schmid
City: Edmonton
State: AB
Zip/Postal Code: T6E 1P9
Depending on how thick you want the stripes, you could ask tonewood dealers for orphan sides.
PostPosted: Wed Nov 18, 2009 6:55 pm
Call Exotic woods in Burlington Ontario .. 905 335 8066 - they can likely help you out ...
PostPosted: Wed Nov 18, 2009 6:59 pm
First name: Matthew
Last Name: Dollinger
City: Beaverton
State: Oregon
Zip/Postal Code: 97005
Might check with some hardwood flooring places too.
PostPosted: Wed Nov 18, 2009 9:25 pm
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
I just found something interesting at A&M Wood (Cambridge, Ontario)... they sell 1" square lumber of turning wood... I Saw ebony, bloodwood, rosewood and wenge... so I asked them if they could have it in 36"... i'm waiting for the answer!
PostPosted: Thu Nov 19, 2009 1:41 am
State: BC
[:Y:] http://www.exotic-woods.com/
CVT Inc.
PostPosted: Thu Nov 19, 2009 10:13 am
First name: Corky
Last Name: Long
City: Mount Kisco
I'm lucky to have a hardwood dealer nearby who has all sorts of exotic woods. I go down every month or so to see what's available in their "scrap" bin. Got lucky and picked up a couple of blocks of sapele for about $7 each - each should yield a good 5 guitars worth of neck and tail blocks. I bought some ebony from them for neck lamination. Realllly expensive, but at the thicknesses I'm ripping off the plank, it should be good for 10 necks. So...
This isn't helping you a bit - I'd check out all the specialty lumber places in your area. Best case is if they aren't marketing to luthiers - you'll have to pick through a lot of boards to get the grain you want, but much less expensive, and fun to go treasure hunting.
Good luck.
